Of course, what any contact thermometer will tell is is its own temperature.
You hope for it to reach thermal equilibrium with its environment and for it to report on the temperature of that enviroment. Usually the mass of the temperature sensor is low compared to the mass of the enviroment.
Not in space.
A conventional thermometer might take a while to reach that point.
From our earth perspective space is a vacuum.
However, that isn't the same as saying that the density (matter distribution) is uniform. In near earth orbit there will be escaping gases etc. I would expect the sun to be the biggest source of ejected matter once we are significantly away from the earth (where is that?).
Within the solar system there is quiet a variation in density and once out of the solar system density drops off some more.
With this density variation will come a temperature variation. So while 4K may be the temperature of the universe, or as IRStuff says, the temperature in deep space, that is probably the mean temperature. It may not vary much between the stars but within the influence of a solar system it will surely increase.
So what is the temperature variation in different parts of the solar system? and what is the limit of the solar system if we use temperature as a boundary i.e. where is the limit where the temperature is indistinguishable from the mean temperature of deep space?
JMW
Eng-Tips: Pro bono publico, by engineers, for engineers.
