Options for attaching checker floor plate to HSS beams
hemiv
89
I have inherited a project where 5/16" HSS is being used for an industrial platform which will be decked in checker plate. The HSS is already purchased.
The previous designer had the floor plate field welded to HSS in overhead position. This is a hell of a lot of overhead welding, and think there should be some better solution to attach them with fasteners.
I have seen Hollo-Bolts used before, but not in this application. I believe it should be fine, but would love to get more opinions.
You could shop weld a small angle to the side of HSS beams that the checker plate can be clipped to. There are numerous clip types out there.
HSS also has radiused corners which complicates that welding.
Is there any specific requirement that all of that area has to be welded/enclosed?
Can some or all of it be welded upside down prior to going into place?
If not, the bolts/clips sounds good.
Or attach only around the edges. You could conceivably get some wind flutter and noise in that case.
Ideally, detail the deck and structure to to facilitate whatever connection needs to be made.
Use self tapping screws. M6 DIN 7500 work well in my experience. Or if your client is fussy use a countersunk screw but that is more work.
All the checkerplate that I use for industrial applications adopt this approach.
