You just have to calculate the different sizes you need and make sure you keep in mind everything else that will influence your design besides the wind load. Cheapest also depends on how you define it. The least material is one way. The least cost is another. You might be able to eliminate material and get weight down but incur so much fabrication cost that you make up for or exceed your savings.
Let's say this is a stud wall with sheathing. Your spacing needs to be a multiple of 8 for the sheathing to connect easily. Typical sheathing in the US comes in 4ftx8ft sheets. Using a large member at a large spacing might be good for the stud, but then maybe the sheathing will not work and you have to reduce spacing anyway. Using a small member with a small spacing might give you the least material weight but will require much more labor to install and you will have more connections to build. It all depends on what sizes and spacings you actually need. Generally, to save the labor costs, contractors I have talked to prefer to use the highest spacing they can even if it takes a larger or heavier gauge stud, or stronger wood species.
If this is a masonry wall, smaller is probably cheaper. If you start getting into very tight rebar spacing, or two bars per cell, it may or may not be cheaper to just increase the cmu thickness.
