Ive been looking into some deisel engines, both NA and turbocharged. For natrualy aspirated version it troubles me that there isnt really a strong control of deisel / air ratio, well apart from the deisel pump (which could offer tight control??). I was wondering what the ranges would be between zero and full load on the ratio's? and is there an optimum, like for gasoline?
Ive seen some NA deisels which have been converted to a forced induction system without any type of intake pressure compensation (I beleive relying on a static fuel pump flow change - turn of screw style adjustment), which would give even more ranges of deisel / air ratio! I'm guessing this could effect the life of the engine much like gasoline type combustion ratio's?
Jakub
Jakub
