cryotechnic
Chemical
In order to optimize our cooling water system we are investigating the adjustments of cooling water of our turbocompressor gascoolers.
The way we adjust the cooling water till now is: Set the total cooling water flow to a point around the value given by the manufacturer. Balans the cooling water over the different intercoolers by adjusting the butterfly valves. When gasoutlet temperatures from the coolers becomes to high (normal temp aroun 25 dgrC) We adjust a little more with the butterfly valves.
What happens by using this system is that we create a lot of pressuredrop over the valves since many valves are half closed and many times we use more cooling water then instructed by the manufacturer.
Gas temperatures are fine, so from that point of few it all works.
My question is: What is the most efficient way of adjusting the cooling water flow? So that we have an optimal gascooling (and most efficient operation of our turbo compressors) and a minimum of pressure drop in our cooling water system, and an optimum total waterflow so that also our cooling water pumps run at the lowest power needed.
Cryotechnic
"Math is the ruler of your potential succes...."
Cryotechnic
