> It is 40 l/m per outlet,mate.
> Typically each theatre having 4 outlets so
> that is 160 l/m per theatre.
Yes, those numbers seem to correspond to what we have here.
And you would indeed count those 4 at 100%, continuously?
And then 7 or 8 OR's 100% simultaneous.
So for 7 OR's you would arrive at 7x160=1120 l/m, correct?
> I am not sure what is bugging you here.
What is bugging me is the fact that these numbers are so much higher than any working installations in other hospitals.
And those are working without problems!
So my questions is, why are all those systems working perfectly even though they are apparently designed all wrong judging from these figures???
Should we conclude that there is a large discrepancy between guidelines and the actually occuring daily use of vacuumsystems?
> There is a detailed analysis provided
> in HTM guidelines.
I'm not familiar with "HTM" or what it stands for?
Where can I find those guidelines?
Note: We are sizing the system for the large flows as requested. However, I would still like to know if there is a genuine necessity for having such a large system, knowing that many smaller systems exist in the field.
