Opening an IGES file with ANSY
benjaminL
Materials
ES
I try to open my .iges file to made CFD FLOTRAN simulation but i can import it.
the error message is allway the same :
"An unexpected error ( SIG$SEGV ) has occured... ANSYS internal data has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected."
I don't undertand, normally it's very easy ..
Thank you for any help.
I can open the .IGES file now,it was maybe an installation problem...
But the size are completly different between solidworks and ANSYS, 210mm become 7.7 in ansys. So all my result are false.
I don't know how i can change the dimansion.
I need your help.
Thank you
ok, it was so easy.
Thank you very much PriamEngineering
