ReverenceEng
Hello world!
So I have a main question and some added mysteries if anyone feels smart and wants a challenge. Maybe I am not seeing something obvious...
I have a simple existing one story building with tilt-up concrete walls and open web steel joists. Design loads are 16 psf dead and 20 psf live roof, reducible. Roof slope is about 1/4" per foot (flat).
I have 30' spans of open web steel joists going north-south with joist girders at each end (pattern is repeated in each direction). Simple framing layout.
Mystery 1: The 30' joists are spaced at 8' O.C. They are 22K4's with 256/128 (annotated). Unless I am wrong, the 256 and 128 are the total and live loads used for design. Well, I can't seem to replicate these numbers. When I reduce my live load from 20, I get about 19.2 (am I screwing up the math?), so I should have 282/154. I can't seem to align the stars with the 256/128. Thoughts?
Mystery 2: Assuming we use the 256/128 for the 30' spans, then my joist girders take 7.68K per panel point...but the girders are called out as 32G 5N 7K...close, but what about the other 680 lbs? Why would these be under-designed?
Main Question 1: I am adding solar. I have checked the loads and the joists themselves are still OK according to Vulcraft tables (barely), BUT if the girders were only design at 7K (or anywhere around there), they are going to be under capacity by a bit. Has anyone ever retrofitted open web joists to boost capacity (only supporting roof above)? I am thinking an easy way is to put a wide flange below and just have the joist bear on it, and then creating simple shear connections to the columns.
Any advice or insight here?
Thanks a bunch!
Brett
Thanks a bunch!
Brett
