Okay, I'm back for a couple minutes.
Y'all know, at least Pat knows, that I am not a novice at non traditional fuels, e.g. Methanol.
It's just been so many years that I have not been up on anything current such as the any problems with AN type anodized fittings and AN lines, rubber and/or teflon. I've not used Methanol with a Weber carb, only Delorto and Amal (which gave no problems with AF ratios around 6:1 or so using 100:1 mix of de gummed castor oil). Fuel cell foam must be changed, a given but, what about the std Carter electric pumps (65gph@ 4.5psi) since the electrics are submerged in "fuel". Jetting for the carb is not a problem as in the past something close to 95% increase in fuel was common (over rich is pretty difficult to achieve unless you just leave the jets out completely---not unheard off ). Reduction in size of air corrector, ???. Size of Aux. venturi, ???.
My old style procedure, post race, was to re jet, blow out lines, drain tank and refill with a bit of race gas and fire up the engine, run until it quit from lack of fuel, blow out the lines and tank. No cell/foam in those days so, I'll probably need to manually clean the ATL fuel cell which will be a PITA but necessary, none the less.
What am I missing?
Rod
