P
pmaru77
Guest
How is flexible used to show a door open part way and door closed in a drawing without creating a big database using instances. I heard that you can use flexible.
I made the door assy a flexible item giving it zero for door closed and then 120 degrees for an option. On my tree the icon is different on the door assy so I assume that the door accepted being flexible. But how do I show it? Especially in a drawing. At assembly level I can just edit the angle, but that screws up the drawing.
So the ???? is ....IS ther a way to show an enclosure with an open door and a closed door in a drawing? Using flexilbe?
The reason for doing this is that there is a cable attached to the box and door, and the calbe will readjust when the door opens.....when using flexible....so I've heard.
Edited by: pmaru77
Edited by: pmaru77
