One Way Sprauge Bearing
123Cat
AU
Can any of you fine men tell me where I can get info on fitting these bearings
For Eg a 10 mm OD bearing , What size hole is it' a 10mm reamed hole or a reamer that cuts 1 thou under size
I want to get it right so the bearing works correctly
Many Thanks
123Cat
You need to refer to the manufacturers data and take his reccommendations, there are many manufacturers of sprag bearings / clutches and although they may all be similar it pays to take there advice respective to their product.
