engjg
- Jan 2, 2015
- 96
What are good options for shapes & FR moment connections (if any) for a one story biaxial Ordinary Moment Frame designed in accordance with AISC 341? I am assuming the structure size does not warrant the price tag of utilizing proprietary connections. For the sake of discussion consider a one story frame with columns in a square arrangement (15'x 15'x 15'), structure is in a SDC D and by height exception an OMF would be permissible per ASCE 7-10.
1. HSS column & HSS Beam; my understanding these are permissible shapes for an OMF per AISC 341 (although not really addressed in the specification)...what about connections that would satisfy 341's OMF requirements? Is a simple fully welded connection if strength checks per 341 permissible? What about continuity plates requirements?
2. HSS column & WF Beam; what about connections? AISC 360 & Design guide 24 shows some options for FR connections...I assume these would be permissible for an OMF 341?
3. Built up WF & WT cruciform; is this permissible to treat as classic WF moment frame in both axis and use typical WF prequalified connections?
