On Tendon cables per ANSI/ASTM A 416 - 74 2
Iasonasx
119
I wonder, with a grade 250 steel why ANSI/ASTM A 416 - 74 on page 384 we get breaking point well before the yield point. I never worked on this subject before but I just wonder if there is some important safety factor that is already incorporated. For example, the 1/4" cable is suggested to break at 9,000 lbf. If we simply apply the cross-sectional area of that and multiply it by 250 kips we get 12,271 lbf for yield, let alone breaking. Not only we disregard all the plastic region but a serious portion of the elastic region of the material. Could someone please give me some insights on this? Thanks!
The "Grade" of prestressing cables does not mean "yield point". It is the minimum breaking stress.
As hokie66 stated, and FYI high strength prestressing steels do not have a defined yield point so the "yield" is often taken as a % strain offset, parallel to the E modulus. Also, the elongation of high-carbon content prestressing steels is considerably less than mild steel. ASTM A416 requires min of 3.5% elongation, but strand typically test close to 8%.
