Sorry to ignore my thread for so long, lack of spare headspace recently…
cibachrome,
I very much appreciate the time and effort you’ve taken to go into this. I can’t pretend I have a handle on everything you’ve said, some of it supports my existing understandings, but at least some is a bit confusing (and I’m afraid some is over my head).
So one of the things you’re saying is that(?); when a ‘sporty’ variant of a road car is factory fitted with a ‘faster’ steering ratio, then this doesn’t ipso facto increase understeer, but, that the handling boffins may deliberately increase inherent understeer (or do you mean steering response?) by whatever means in order that ‘the average driver’ won’t be scared witless at highway speeds by highly reactive steering, while still being ‘thrilled’ by the steering ‘directness’ at slower speeds?
So, in such a case we may find a ‘sporting’ variant fitted with a ‘faster’ steering ratio that when pushed may actually be a worse offender in the excessive understeer stakes than is the base model shopping trolley?
That seems easy enough even for me to understand and I can see the rationale behind it, but am I understanding this part of your comment correctly?
With my Accord I used to feel that the steering ratio was too low geared, but after all the changes I’ve made to the car the steering feels a lot ‘faster’, even though the steering ratio is unchanged (and still on stock sized tyres on the stock wheels). The car still understeers, but a lot less than it used to, and is far more responsive at all speeds.
I am still having trouble understanding how the “steering system is almost always the biggest contributor” to understeer, by which I don’t mean to suggest you’re wrong, just having trouble grasping how it is so.
I was under the impression that it is the front / rear distribution of dynamic weight transfer that is the largest factor affecting understeer / oversteer characteristics (all else being equal such as contact patch presentation to the road etc. etc). You say (at least I think you’re saying) that it isn’t, so I’m now trying to deal with a significant tilting of the Earth’s axis…
If the distribution of dynamic weight transfer (whether through geometric and / or elastic vectors) isn’t very important to front / rear grip bias, why can changing the roll couple (geometric and / or elastic) affect understeer / oversteer so strongly…?
You start to lose me when you speak of “linear” and “non-linear” understeer, and deflections that occur within the steering mechanism contributing to understeer (e.g. torsional flexure in the steering column shaft etc). As best as I can interpret it, it seems like you’re talking about a difference between ‘real’ understeer’ and a ‘perceived’ understeer, though I’m not at all sure I am getting the correct gist of your comments.
My conception of understeer doesn’t include deflections between the driver and the wheel rims, only the relative front vs rear slip angles at the tyres. In this case deflections (and changes in effective leverages as caused by single cardan joints or unequally angled double cardan joints, or steering arm arcs etc) within the steering may well mean the steering wheel is turned more for a given corner taken at X speed / lateral acceleration, but in my private universe this doesn’t equate to an understeer, just a vagueness, or rather, a slightly erratically ‘elastic’ steering ratio (not really a good thing, but hard to avoid entirely).
I keep feeling I’m thinking of something slightly different to what you’re thinking of, but then maybe my conception is just too simplistic…
At any rate, with my PAS disabled I haven’t noticed any change in the handling balance of the car, though of course this doesn’t mean that none has occurred, I may just not be sensitive enough to pick it. Something that made a far greater difference was the deletion of the front ARB (decreasing understeer, though turn-in steering response also lessened, requiring an increase in front damper stiffness and stiffer damper rubbers to ‘re-sharpen’ the turn-in).
I know that a neutral handling car is something of a phantom that doesn’t usually exist, or is very difficult to drive when it does, and that a car that feels ‘neutral’ would generally just have less understeer than is usual with most cars.
My understanding is that if you get too close to an (on average) neutral set up then the car also gets too close to repeatedly stepping over the line into abrupt oversteer. Better to have a slight understeering tendency that can be provoked into a more easily controlled neutrality or oversteer, than a fundamentally neutral tendency that readily trips into a difficult to control oversteer (possibly fluctuating too easily between understeer and oversteer). If that’s not too simplistic…
Pat, I remember the Bartlett Camaro at Bathurst, on it’s roof (7 out of 10 for that crash…). Years ago I had a brief drive in a “GT” Falcon (XC from memory) that had had the PAS disabled, and it was hard work to the point of being almost un-drivable (and I have good upper body strength, maybe the 13” steering wheel didn’t help…).
It’s not so bad with my Accord, I can easily accept the increased effort required to steer it with the PAS disabled (even with more than double the stock caster), but my wife won’t I’m sure.
As far as the “short story” goes (i.e. “don’t turn off the PS pump?”); it seems that (other than a suggested increase in understeering tendency that I’m not sharp enough to understand and can’t feel) the only answer to my question about other not so obvious downsides to disabling the PAS is cibachrome’s comment re torsion bar non linearity being excacerbated by the lack of assist.
Since this was suggested as a potential issue, in some circumstances I suspect I can occasionally detect (psychosomatically?) some slight ‘woolliness’ that might (or might not) be attributable. If so then it doesn’t appear to be a significant problem (I still far prefer the PAS disabled), but it would be interesting to try a welded up assembly as per cibachrome’s suggestion.
Of course this is only an option if the PAS belt remains off permanently, which it might not, or at least it’s good to leave the option open (and I may or may not get around to fitting an AC clutch on the pump).
Any rough idea of what might be a typical range of input shaft rotation / T bar twist before the connection between the input shaft and the pinion becomes ‘solid’ in the direction of steer?
