on line resources 2
robinxie
Chemical
CA
Could anyone provide some on line resources regarding desalter, furnace and any refinery equipment specifications/data sheets? Thanks a head.
hello,
one source can be the API, usually if you have a project the know-how provider will supply the datasheets.
equipment suppliers also can supply datasheets.
regards,
roker
I found that lead contractors and licensors websites (Foster Wheeler, UOP, as an example) are very valuable for self-training purposes. Again these could be achieved by consulting operative technical papers on the unit operations You mentioned (desalting, thermal cracking, distillation et cetera)
Thx a lot, PB500. Could you please indicate more contractors and licensors websits?
This is just a sample list, however due to strong concentration in the industry the following are nearly synonimous of a specialty segment
CRITERION CATALYSTS
IFP look at "IFP Knowledge Hub" in particular;
AXENS process units licensing for aromatics, middle distillates, et cet
CDTECH (ABB LUMMUS GLOBAL - CRI) process units for catalytic distillation of gasoline blends (by the way, also take a look at EPC work of SNAMPROGETTI
JGC CORPORATION for other unit processes
HALLIBURTON KBR for FCC, hydroprocessing and resid upgrading
SHELL GLOBAL SOLUTIONS
Personally, I have preferential interest in aromatics and heavies upgrading, so I also take into account
CHIYODA CORP TOJO ENGINEERING CORP TEC both at "Technology" section.
Thank you very much, PB500.
