Ok Solidworks brain trust pros: 1
asv4k8
Aerospace
May 3, 2010
38
I have a complex shape on my hands that is giving me trouble, see attached pictures and file:
Here is the picture with explanation:
and the solidworks part file is also attached. I just cant seem to get the right lofted cut, thanks in advance for the help...
As always thanks in advance and if you need ANY automotive engineering or performance advice feel free to email me as I am not on here that often.
You're going to have to dig into your surfacing toolkit to fix this model. It shouldn't pose too many problems, just play around with deleting faces and filling them up again. The final solution will depend upon your design criteria.
Dan
Dan's Blog
I will look into the surface tool kit, any idea what tool in particular would do the trick?
Ok thanks I'm going to play with it in a bit here.
Im still having trouble with it, I deleted the faces I dont want but I am unsure how to loft the edges back together....
Ok here is where I am at, some faces deleted and need to "re-loft" them
I'm not 100% sure what you're trying to accomplish.
Try: Select the face, add a sketch with the lines, go to the mold toolbar, split-line, then delete the face.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
I just need to trim this face where i have the line here, then i can worry about re-lofting
I got it, by adjusting my lofted cuts, never could figure out the face surfacing....
here is another shot with a more clear rendering:
thanks, now if i couls just get the filet command to work on the edges of all those raised "guides"...
i can try that..... give me a second
no that didnt do the trick either.... odd, some of those surface commands dont give good results....
