It is understood that the 2 major properties affecting crude oil 3-phase separation are Temperature and Pressure. However I do not fully understand the rational of which way you might want to drive these for optimum production.
Temperature – ideally this would be high (?) because the density differential between water and oil is increased at higher temperatures because of different specific heat capacity of the fluids. Also the viscosity is increased at higher temperatures so the droplets separate easier. But what constrains this? Is it because more gas is retained within the oil at higher temperatures, which can cause problems with pumps?
Pressure – separator pressures are often lowered to increase the production rate, this increases the pressure differential between the well and the separators hence promoting more flow. However does it not mean that more gas is flashed off (?) also at lower pressure you actually have a lower mass/volume than at the higher pressure so is there actually more oil?
I would be grateful if somebody could clarify these points for me
Cheers
Cheers
