oil droplets /water separator design 2
TN
Hello all ,
I'm wondering if anyone have an idea how to design a separator that will be installed on a pit
after oil treatment unit for removing oil droplets from water ; the flow rate is 2 gallon/ min .
I have followed API 421 but it doesn't work for this small flow rate .
THANKS A LOT !
REGARDS !
Oil separators are typically purchased as an equipment item that is already designed and fabricated.
Link
I'm assuming you mean what is typically referred to as an "API separator", i.e. a long thin tank which is calculated to allow oil of a certain droplet size to migrate tot he surface for final skimming?
Most people nowadays, as bimr says, would buy a small pre-packaged unit or a tilting plate interceptor for such use. Far more compact and efficient.
Also API 421 separators nowadays often don't meet the discharge requirements.
