Oil into lakes and rivers is an event we all need to be mindful of. Bilge water will often have some oil, and the Oil-Sorb Pads are effective here, provided they are not too overloaded with waste oil.
Does anyone know of environmentally acceptable oils that are biodegradable and that could be discharged into the water? I would think things like Tallow, or various vegetable oils, castor oil, palm oil, etc. would be OK, but I do not know the rules here.
It would be good to know of some oils that would not bring environmental problems. Please let us know about this IF you have solid data. Telling the authorities that "I think this oil discharge is OK, Joe from the forum said he thought it was acceptable because he heard about it from a friend...." would not be the kind of information needed here.
Another point: Two Stroke Outboard Mix Oil. I know that stuff is petroleum oil mix, is discharged into the water, and there are millions of 2-stroke outboards in service. Yes, they will eventually be outlawed, but they spew many tons of oil directly into our waterways. For example, a 100 HP outboard will put 1 to 2 pounds of OIL into the exhaust every hour at full throttle. There are thousands of these boats running on the water as I write this. What are the regulations regarding these types of discharge?
