edison123
- Oct 23, 2002
- 4,508
Are there any rules/references on what should be the Oil clearances (side & top) for white metal sleeve bearings ?
Are the clearances related to speed / shaft dia ?
For example, what should be the clearances for a 160 mm dia shaft running at 3000 RPM ?
* If a little knowledge is dangerous, then I am the safest person in the world *
