Dear members,
We are designing a offshore platform and have come across a basic question on design of hazardous open drainage. There are limitations in treating that and owner decided to collect the contents and ship to onshore. Having decided that they wanted to size the collection tank as small as possible which is possible only by avoiding rain water falling on the collection areas. Since bunds (coaming) is provided under all hydrocarbon vessels the total drainage load has been estimated to be vety high.
In order to overcome the above, Owner raised a query why the pressure vessels (Flare KO Drum, Methanol Drum etc.)need bunds below them. Their point is that since all such pressurised vessels are provided with closed connection to the closed drainage, spillage is not expected from them and hence bunding not required. They are OK with providing bunding for atmoshperic tanks such as diesel and lube oil tanks to cater to overflows etc.
I referred to Shell DEP also but it does not give any clarification which equipment call for bunding and whether Owner's point is right (removing bunds for pressurized vessels). Advise/feedback from you is highly appreciated.
Techv
Techv
