offsetting lines in the sketcher (2001)
  • Thread starter Thread starter rob1wal
  • Start date Start date
R
rob1wal
Guest
Hi All,
Is there a way of offsetting a line in the sketcher, I know you can offset part edges but I want to able to offset a drawn line, x amount of times.
cheers
Rob
Hello Rob yes you can.
1. Sketch a line and get it dimensioned and resrained.
2. Select line and click on EDIT/Copy. this will give you one
copied line.
3. Now select both lines and repeat the above step.
4. I don't believe you can copy and offset a number of times
like you want to but this does work.
Or, when you are sketching, choose the existing line as a reference and just start sketching parallel lines. You might have to sketch centerlines perpendicular to your reference line at the reference line ends. This way might be the quickest way to duplicate lines. Once you have sketched so many lines, you can then use the selection tool to window your lines, right click, choose copy and place your copied lines.
Another neat trick is to sketch lines perpendicular to your copy line, make them construction lines with a constraint of equal to the first sketched perpendicular construction line. This way you have one dimension, not many controlling your sketched offset lines.
