C
cotton
Guest
Hi!
I have massive problems when using the tool "create an entity by offsetting an edge" in sketch mode. If I for example use the option loop, and then change the dimensions of the reference surface, the part doesn't regenerate. And the most annyoing thing is that the system doesn't tell me that the references has changed. The problem doesn't end there. I sometimes can't change the offseted dimension.
These problems first showed up for us when updating to Wf3. We have tried several updates and are now running M140.
Anyone else having the same problem?
