OFFSET SURFACES FROM A SOLID
pete1960
Automotive
Sep 4, 2006
3
I have a solid model in WF2 and I want to select several surfaces to offset to use as a cutter. When I select the surfaces then edit - offset it seem to only select 1 of the original selection. If I copy the surfaces then edit - offset, this works but leaves the original surface which I dont want. Any ideas? (before I do this in I-deas)
If you can get a sketch plane that works, you could possbly do a draft offset if you just want to thicken a region. If you are looking to make a quilt that is offset from a group of surfaces on a solid then you have to do the surf-copy / edit, offset method. Yes it does leave the original surf-copy, but just put it on a layer and blank it.
I've been wishing for multi-solidsurface selection with the offset for a long time.
Jason Williams
K Development, Inc.
