jwlynn64
- Jul 20, 2005
- 74
I just upgraded to 2010 SP2 from 2008 SP5. I routinely use the offset entities command (with select chain checked) to produce an offset of a prior sketch.
Since I have upgraded, the select chain function doesn't seem to work. I now have to select approximately 10 sketch segments to get the same results I used to get with only one selection.
Any suggestions or help would be appreciated.
