Came across a relatively complex problem at work. I am fairly new to S&T design, so thought I'd get opinions from engineers on here. Designing a 'suspended' slab on ground with cont. edge beam supported on regularly spaced piles with an offset column (wall) load.
Would ideally prefer to design using a S&T model as per the below but the reaction at B would put significant shear at the top of pile, reaction at A can be added to the slab diaphragm forces.
Alternatively I could consider it as a slab run as per the below and reinforce accordingly.
Currently, I am designing as per the second option and thickened the slab joining into the beam to achieve the bending capacity at the step. However I wanted to understand which would be the correct way to go about designing and detailing this beam.
