I really don't ever bash SolidWorks--I love SolidWorks. But I'll make an exception in this area. Isn't it stupid to include an option in the installer that will ALWAYS lead to disaster of the installation? Can we not rid ourselves of this stupid option in the installer after eight years?
OK, now that that's out of the way. .. MMike1, was this an upgrade or a fresh install? If it's a fresh installation, did you separate the directories (install 2006 in a directory marked "SolidWorks2006" or similar)? If not, you'll need to do an uninstall and clean reinstall. Check CorBlimeyLimey's post and the other FAQs on this subject while you're there--good stuff.
So when you guys create a new folder for the clean install, what do you do with the SolidWorks Data folder? Do you make a version-specific one of those, too? The problem that I ran into is that you then lose all your links to the toolbox parts.
I know that Scott runs several versions on his box and I'm interested in keeping the old install.
I know I know....I should have done a clean install...but my wife didn't want me dinking on the computer in the basement for too long... so I figured I give the upgrade option a shot. (Like Theophilus said...why even have the option if it's going burst into flames?)
Anyhoo.... I'll play with it over the weekend....
Damn you 2006! KAAAAAAAAAHHHHHHHHHHHNNNNNNNN!!!!!!!!!!
Right--but you definitely need your own SW data folder for each version. I hate the headache of missing parts in a directory, so I always put a copy of toolbox parts in the directory I'm using them. There have been so many times a client gives me SW parts with all sorts of missing fasteners because they didn't copy all their parts into the directory.
Chris, yeah, working late as usual (last night). You too, eh?
Delete folders in the registry. Start, Run, type “regedit” look under HK Current User, Software. Delete Bluebeam Software, eDrawings, SRAC, S.R.A.C., SolidWorks
Delete the same as above under HK Local Machine.
I do this with a registry cleaner. Uninstall, delete remaining folders and files, reboot, run the registry cleaner to automatically delete old registry entries, reboot, and then perform a clean install. It's a good idea to do this--keeps it truly clean.
I was looking on the SWx forums. I saw someone had the same probelm I did. "They" said the is could be a graphcs card problem. I checked the site for drivers and approved cards and all that. I can't even find my card at all on the list. It'an ATI Radeon 9550....
Yeah. I had checked the SWx to see (or not see as the case may be), my video card. 2005 had always been a little choppy with it. I guess now 2006 is just totally out of the question....
And I guess for the sake of....well I'm not sure what it would be for the sake of... what what I saying again?
Oh yeah... Here's the thread to which I was referring...
Basically the same thing happened to me. And this guy also has an ATI card....
At home I run a GeForce 6800GT with no problems. I chose it as I wanted to play games too and didn't wany to spend $$$ on a quadro. Good card for $300.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP0.0 on WinXP SP2
