Odd vessels
rhusky
I always seem to get the weird stuff...okay, I have a silo with a cone type head, and an eccentric cone transition to 6" nozzle. Any ideas on how to enter this puppy into compress??? Any???
(1) COMPRESS provides option for transitions under the component menu. However, both ends of the transition are assumed to be "open"; ie: it will not have a closed end as for a cone type head. However, you should be able to enter a small value for the small end diameter and be done with it.
(2) COMPRESS does not provide for piping or other components to be attached to the end of a nozzle other than flanges, bolted covers, and heads.
However, you can design the nozzle neck as a 6" cylinder in a second COMPRESS file. Then attach a transition to the end of the cylinder. This will get you calculations for the cone and the cone-cylinder junctions. COMPRESS provides option for eccentric cones only for horizontal vessels, not vertical.
Tom Barsh
Codeware Technical Support
