Hi everyone. I am in the midst of testing a tube and shell gas cooler which is giving me (as noted in the subject) odd performance. Background - unit is liquid (unnamed) on shell side, gas on tube side. Gas on tube side is about 80degC dewpoint and arrives at the cooler inlet at 270degC and leaves at a variety of temperatures, some of which make no sense. Coolant is at 65-70 degC (below gas dewpoint). Coolant boiling point is ~230degC at operating pressure. The unit is a cocurrent setup and the cooler is unbaffled. The outlet gas temperature will rise as the coolant flow is increased (odd!!!) if the coolant flow was very low to start with. When increasing th flowrate thru the shell side, a certain flowrate is reached where the gas temperature will dive. After this point is reached, a decrease in flow rate will increase the outlet gas temperature. The coolant temperature (bulk at outlet of cooler) does not vary by more than 20degC above the inlet of 65-70. Can anyone dream up a reason for the "hysterisis" of the system. I have some odd theories, but none are satisfying. Has anyone ever seen this type of phenomena?
