Danice,
To add to the info provided by hydromech....
It is customary to use plastic inserts in the mating faces of the body on low pressure floating ball valves. In these designs the main seat which contacts the ball is also a sold plastc insert and I assume it is not this aspect of the design to which you are referring. This seat insert fits into a cavity in the body (seat pocket) and seals against side wall or rear wall of the seat pocket. It also seals against the ball. In these applications the material is normally PTFE because of its high and low temperature properties and chemical inertness. These designs can also use PTFE seals in the stem area.
In higher pressure designs (trunnion mounted), it is customary to use orings to seal between the body members. In these designs the plastic seat insert is normally retained in a metal seat holder and there is normally an oring on the metal seat which seals the seat holder against the body (seat pocket). Again the plastic insert retained in the seat holder is also used to seal against the ball. Also, the stem and trunnion seal would be oring type.
