EngineerPhil
Petroleum
Can anyone help?
Is there a rule of thumb that roughly describes the relationship (for a seal to perform) between the contact sealing force/stress on the o-ring to the applied fluid pressure?
I have a seal that doesn't always work and FEA suggests it does. If the applied fluid pressure is too great then it could blow past the contact sealing pressure, however, there must be some sort oflimit to this?
Just a bit stuck.!
Just a bit stuck.!
