strokersix
- Dec 7, 2002
- 344
I need to specify a lubricant for gearboxes with plastic gears. Some of the gearboxes have acetal/nylon gear pairs and some are nylon/nylon all gears neat material. The gearcases are 30% GF polyester with ball bearings supporting the gears. Gearcases are sealed enough to keep dirt out but could allow some water intrusion. The overall configuration is crossed axis helical with 45 degree helix angles. Surface speed is in the 50 feet per minute range. Environment is outdoor machinery that needs to operate from 20-120 degrees F. Typical temperature 50-80 F. Gearbox operating temperature has been shown to be 20-40 degrees above ambient. Gearbox life needs to be 1000 hours continuous running with no additional lubrication.
We are currently using Mobil 28 grease which performs well but seeems to be separating. This causes undesireable seepage which is more of a cosmetic than functional problem but needs to be fixed. Can anyone give any general or specific recommendations on appropriate grease selection? I am interested in low friction to minimize gear temperature rise and eliminating the seepage problem.
Thank you.
Thank you.
