NXOpen.tag cannot be converted to NXOpen.Face
EngProgrammer
Aerospace
Dear Forum,
I am using NXOpen function theUfSession.Modl.CreateRevolved(objarray, {"0", "360"}, origin, vect, FeatureSigns.Nullsign, features) to create a revolved sheet body from a line in the xy-plane. Next I want to extract the face of this revolved and pass it into another function to create intersection of curves. How do I cast an NXOpen tag into an NXOpen face?
Thanks in advance.
You have to use TaggedObjectManager to get the NXOpen TaggedObject, then cast that to your object type. Something like:
Code:
TaggedObject to = theSession.taggedObjectManager().get(yourTag);
Face yourFace = (Face)to;
Graham Inchley, Systems Developer, Sandvik Coromant. HP EliteBook 8760w, Win7, 8GB. Developing in: Java | C | C# | KF
Production: NX6.0.5.3 MP5
Testing: NX8.5.3.3 MP4 64bit | NX9.0.2.5
My programming language is VB.NET and NX9.
I am using the following function theUfSession.Modl.CreateRevolved(objarray, {"0", "360"}, origin, vect, FeatureSigns.Nullsign, features). The revolved surface is getting created but I am having problems casting the features(0) into a face. I've journaled the activity of taking the revolved sheet body and intersecting it with another sheet body to try and finding the casting.
Here's the snippet from the journal:
Dim bodyFeature1 As Features.BodyFeature = CType(workPart.Features.FindObject("REVOLVED(13)"), Features.BodyFeature)
Dim face5 As Face = CType(bodyFeature1.FindObject("FACE 67700 {(0,0,34) REVOLVED(13)}"), Face)
With your current methodology, you can get a reference to the revolve feature with the function given by grinch33. Once you have a reference to the revolve feature, you can use the .GetFaces method of the revolve feature to get references to the faces.
It might be a bit easier if you create the revolve with a RevolveBuilder; this will give you a reference to the newly created revolve feature without messing about with tags.
www.nxjournaling.com
I have a solution. Here's what I ended up doing. Here's the code snippet below. I ended up changing the revolved surface from 0 to 360 to 0 to 180. Therefore, hopefully ending up with one face from the revolved. I first had to get the feature name for some reason I don't completely understand. However, if someone hs an alternate method I would definitely be interested in alternatives. Thank you.
theUfSession.Modl.CreateRevolved(objarray, {"0", "180"}, origin, vect, FeatureSigns.Nullsign, features)
Dim featName As String = Nothing
theUfSession.Modl.AskFeatName(features(0), featName)
Dim bodyFeature1 As Features.BodyFeature = CType(workPart.Features.FindObject(featName), Features.BodyFeature)
Dim hoop() As Face = bodyFeature1.GetFaces()
Dim TestIntersect As Features.IntersectionCurve
TestIntersect = Nothing
For iii As Integer = 0 To hoop.Count - 1
Try
TestIntersect = createIntersectionCurves(Airfoil, hoop(iii))
Exit For
Catch ex As Exception
If iii.Equals(hoop.Count - 1) Then
'Throw New Exception("Failed to Find Intersect of Radial Hoop with Airfoil")
Return Nothing
End If
End Try
Next
The code below will revolve a line about the X axis and report some information about the resulting face.
Code:
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim workPart As Part = theSession.Parts.Work
    Sub Main()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "NXJ journal"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        'create line to use in revolve feature
        Dim revolveLine As Line
        revolveLine = workPart.Curves.CreateLine(New Point3d(0, 25, 0), New Point3d(25, 25, 0))
        'revolve about absolute X vector
        Dim thePoint As Point = workPart.Points.CreatePoint(New Point3d(0, 0, 0))
        Dim theDirection As Direction = workPart.Directions.CreateDirection(thePoint.Coordinates, New Vector3d(1, 0, 0), SmartObject.UpdateOption.WithinModeling)
        Dim axis1 As Axis
        axis1 = workPart.Axes.CreateAxis(thePoint, theDirection, SmartObject.UpdateOption.WithinModeling)
        'create the revolve builder
        Dim revolveBuilder1 As Features.RevolveBuilder
        revolveBuilder1 = workPart.Features.CreateRevolveBuilder(Nothing)
        revolveBuilder1.Limits.StartExtend.Value.RightHandSide = "0"
        revolveBuilder1.Limits.EndExtend.Value.RightHandSide = "360"
        revolveBuilder1.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Create
        revolveBuilder1.Tolerance = 0.001
        revolveBuilder1.FeatureOptions.BodyType = GeometricUtilities.FeatureOptions.BodyStyle.Sheet
        revolveBuilder1.Axis = axis1
        'create section for revolve builder
        Dim section1 As Section
        section1 = workPart.Sections.CreateSection(0.00095, 0.001, 0.5)
        section1.SetAllowedEntityTypes(Section.AllowTypes.OnlyCurves)
        section1.AllowSelfIntersection(False)
        Dim curves1(0) As IBaseCurve
        curves1(0) = revolveLine
        'create curve rule
        Dim curveDumbRule1 As CurveDumbRule
        curveDumbRule1 = workPart.ScRuleFactory.CreateRuleBaseCurveDumb(curves1)
        'create selection intent rule
        Dim rules1(0) As SelectionIntentRule
        rules1(0) = curveDumbRule1
        Dim nullNXObject As NXObject = Nothing
        'add our input line to the section
        section1.AddToSection(rules1, revolveLine, nullNXObject, nullNXObject, revolveLine.StartPoint, Section.Mode.Create, False)
        revolveBuilder1.Section = section1
        'revolveBuilder1.ParentFeatureInternal = False
        Dim feature1 As Features.BodyFeature
        feature1 = revolveBuilder1.CommitFeature()
        revolveBuilder1.Destroy()
        'report the feature faces
        lw.WriteLine(feature1.GetFeatureName & " contains: " & feature1.GetFaces.Length.ToString & " faces")
        Dim theFaces() As Face = feature1.GetFaces()
        For i As Integer = 0 To theFaces.Length - 1
            lw.WriteLine("  face " & i.ToString & " color: " & theFaces(i).Color)
            lw.WriteLine("  face " & i.ToString & " layer: " & theFaces(i).Layer)
            lw.WriteLine("  face " & i.ToString & " area: " & FaceArea(theFaces(i)).ToString & " square inches")
            lw.WriteLine("")
        Next
        lw.Close()
    End Sub
    Function FaceArea(ByVal inputFace As Face) As Double
        Dim theFaceArea As Double
        Dim measureFaceBuilder1 As MeasureFaceBuilder
        measureFaceBuilder1 = workPart.MeasureManager.CreateMeasureFaceBuilder(Nothing)
        Dim unit1 As Unit = CType(workPart.UnitCollection.FindObject("SquareInch"), Unit)
        Dim unit2 As Unit = CType(workPart.UnitCollection.FindObject("Inch"), Unit)
        Dim objects1(0) As IParameterizedSurface
        Dim measureFaces1 As MeasureFaces
        Dim added1 As Boolean
        measureFaceBuilder1.FaceObjects.Clear()
        added1 = measureFaceBuilder1.FaceObjects.Add(inputFace)
        objects1(0) = inputFace
        measureFaces1 = workPart.MeasureManager.NewFaceProperties(unit1, unit2, 0.999, objects1)
        theFaceArea = measureFaces1.Area
        measureFaces1.Dispose()
        measureFaceBuilder1.Destroy()
        Return theFaceArea
    End Function
End Module
