NXOpen AssemblyConstraint question
MANox
PL
Hello everyone,
I try write journal for flip direction of concentric constraints (many in one operation).
I have problem and I can't find solution.
I can select constraints as "NXOpen.Positioning.DisplayedConstraint".
For flip operation I need type "NXOpen.Positioning.ComponentConstraint"
Maybe somebody have idea for change NXOpen.Positioning.DisplayedConstraint to NXOpen.Positioning.ComponentConstraint.
Operation:
Code:
componentConstraint1 = CType(displayedconst, NXOpen.Positioning.ComponentConstraint)
don't work [dazed]
Best regards
MANok
NX12
TC10
The .DisplayConstraint is the graphical representation of the constraint; it has a .GetConstraint method that will return the positioning.constraint that can be cast to a component constraint.
www.nxjournaling.com
Many thanks cowski, You are Great.
If somebody need journal for Flip Alignment of selected constraints, here it is:
Code:
'Journal create by MANok 03.02.2021
'Journal Flip Alignement of selected constraints
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Reverse_const
    Sub Main(ByVal args() As String)
        Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
        Dim workPart As NXOpen.Part = theSession.Parts.Work
        Dim displayPart As NXOpen.Part = theSession.Parts.Display
        Dim componentConstraint() As NXOpen.Positioning.ComponentConstraint
        If (SelectConstraints(componentConstraint)) = Selection.Response.Cancel Then
            Exit Sub
        ElseIf IsNothing(componentConstraint) Then
            Exit Sub
        End If
        For i As Integer = 0 To componentConstraint.Length - 1
            componentConstraint(i).FlipAlignment()
        Next
    End Sub
    Function SelectConstraints(ByRef componentConstraint1() As NXOpen.Positioning.ComponentConstraint) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select a constraint"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        Dim prompt As String = "Select constraint"
        Dim selObj() As TaggedObject
        With selectionMask_array(0)
            .Type = UFConstants.UF_constraint_type
            .Subtype = UFConstants.UF_constraint_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName OrElse Selection.Response.Ok Then
            Dim i As Integer = 0
            For Each element As TaggedObject In selObj
                Dim dispconst As NXOpen.Positioning.DisplayedConstraint = Utilities.NXObjectManager.Get(element.Tag)
                ReDim Preserve componentConstraint1(i)
                componentConstraint1(i) = dispconst.GetConstraint
                i = i + 1
            Next
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
End Module
Best regards
MANok
