NX9 - Delete Face Issue
spadazenon
GR
Hi. When I try to delete a hole face with synchronous delete face, I get an error "delete failed because the remaining faces cannot close the area left...".
I've uploaded a video and the part.
This was not happening in previous NX releases.
Am I doing something wrong?
 http://files.engineering.com/getfile.aspx?folder=c0541305-45bd-46d4-92a0-11cf6c2a13cb&file=delete_face.zip
I could not see the video but I have a guess.
Use your rectangle to select the face(s); there may be a very small face that is hard to see and needs to be deleted so the remaining faces trim properly, and that the rectangle will find
The error message also suggested selecting cap faces. Did you try that as well?
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
I had NO problems whatsoever deleting any and all of the holes in your part file (see attached video) using the Delete Face function with either NX 8.5.3.3 or NX 9.0.3.4.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=82dc7fc7-4938-4e6c-9eb7-bfac38e3b8c9&file=Delete_Holes_JRB-1.mp4
I had no problems, too.
I would try do reset the dialog of delete face using the round arrow in the delete face dialog title, and try it again.
this could even be a graphics issue
make sure you have the "right stuff" on your computer
I should have written
this could even be a graphics card issue
Thank you all for your replies and your time.
@Jerry1423 Thankfully it was not a graphics card issue.
I do not know what I was doing wrong (especially when I watched how easily John Baker deleted all inner faces), but it was quicker for me to re-install NX and somehow the problem solved. I must had gone something wrong with the first installation or the updates.
Thanks again,
Spada
