Xwheelguy
Automotive
- Mar 17, 2004
- 2,048
I've noticed this for a few NX major releases - and due to the way my employer's computer nazis have NX setup, I'm unable to tell if this is an issue with NX, Windows or limited to within my company. I was wondering if anyone would care to test something out for me? NX8 is fine, but NX9 would be better.....Windows 7 is probably a must (64bit here).
Perform a CGM Export (or any other export) and under the Destination "area" of the dialog (make sure Destination is visible or expanded) click the Browse... button and a Common File Dialog should pop up (see attachment below for reference - stolen from Web). On the left, you should see shortcuts such as Recent Places, Desktop, Libraries, Computer, Network. Select Desktop, set the file name you want (such as test.cgm) and try to press OK. My dialog will NOT allow me to use this shortcut to save any exports - it always switches to computer and forces me to pick the path manually (C -> Users -> your username here -> Desktop.
Anyone else getting this or is it just me? It drives me insane to have to manually browse to my Desktop whenever this Common Dialog pops up in NX - yes, I know it saves the last location, but it makes the purpose of the shortcuts on the left useless if I change from Desktop.
Thanks in advance to any who help out.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Tim Flater
NX Designer
