Here's the Schoolbook solution. A Through curve Mesh using the endpoints of the arcs as points in the primary strings. ( = three strings in primary direction of which 2 are points.)
The resulting surface is "compressed" in the ends which can be seen if you turn the display mode into Static Wireframe.
In this case it's probably ok since the cross direction is circular. ( The pole structure looks good.)
Tomas
