NX7.5/8.5 to NX9.0 Impeller Problem
pzang
4
Hey Folks,
I am trying to replicate the Impeller Assembly assignment from NX7.5/8.5 in 9.0 and I am having some trouble with the Impeller Vanes. I Trim the vanes back OK but when I try to add the Variable Edge Blend Radii, the vanes believe they are hollow. And I am also having trouble with the Instances of the vanes. Could you help??
 http://files.engineering.com/getfile.aspx?folder=f8c31d5f-68cd-4185-8bce-f52b40f062d3&file=zang1234-3.prt
Since you're now working in NX 9.0, this is how I would create this model (see attached), using 'Pattern Face' instead of 'Pattern Feature'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=63929076-d89b-438a-a5c8-9b3caf8e5370&file=zang1234-3_JRB-1.prt
