I'm having a trouble with replacing a component in an assembly drawing. I'm trying to replace a sub-assembly with a higher revision of that assembly. (It should have been done when the sub-assembly was revised, but was not.)
When I do a Replace Component and put in the higher rev level, the layers get all messed up in my drawing views. It seems to be putting the components of that sub-assembly on different layers than what there were originally assigned to. Is there a simple way to fix this or will I have to go back through the sub-assembly and reassign each part to the correct layer?
Thanks,
Stephen
Thanks,
Stephen
