NX6 cutting image
bramvangestel
Automotive
Aug 19, 2008
7
Does anybody know where i can alter the option to increase my workspace. At the moment NX6 is cutting a piece from my image when i rotate it, making me pretty insane every time i want to select something outside this viewing area. In nx 4 it used to be under preferences-visu-perspective-fit planes to extend
Something like Preferences>Visualisation Performance look through the tabs they changed a bit from version to version and try turning off "fixed frame rate" and "view frustrum culling". You description isn't specifically describing this problem but is sounds similar enough that it wouldn't hurt to check these settings.
Cheers
Hudson
sometimes, if you switch from a small part to a very large one, I've seen this problem occur. In my cases, a quick Fit View zooms the screen to fit the model and eliminates the "cutting" you describe.
