tomstickland
Every time I find something that appears to be illogical I'll add it in here. I can then see if anyone else agrees, and hopefully the NX6 developers might be able to take it on board.
1)OK, Apply, Cancel.
Different menus behave in different ways.
Sometimes if you OK the action it occurs again.
Sometimes you apply things then cancel.
Sometimes you OK to make something happen and then exit.
2) Menu clicks required to edit a parameter.
The new hole system is a lot better than the old one and now a double click allows you to edit the dimensions. This is good.
However, old features like slots, you still have to go through:
right click
edit dimensions
then select add, delete or edit
then edit
then ok, then ok again
3)Drafting and model views
When several files are open, some are on drafting view, others are models. As you navigate between the windowns you have to keep changing from model to drafting application. Why can't the various windows remember what application they are running?
4)Quickly finding specification files
If I have a model open and want to see any specifications, the only way seems to be to do a search in the file-open window. Is there a direct way to get to specifications?
5)Editing arrays
Why can't I click on an instance to edit the feature and on the array to edit the array? Instead I have to click on an instance and then select "edit feature" or "edit array". This makes the whole process more labourious than it should be.
right click
edit dimensions
then edit
5)Editing arrays
