NX5: Adding features to an array
Simon205
151
Anyone know how if you have an existing array of features, and then want to add more features to it, how you include them into the original array? Editing the 'instance feature' dialog brings up the array's dimensional properties, but not which featuers it looks for.
Thanks,
Simon
Hello Simon, it depends of the feature, for example, if you add an edge blend you can check "Blend all instances" in the settings drop down section.
Frank.
I'd recommend Instance Geometry over Array unless there's something that Array is doing that Instance Geometry cannot.
Tim Flater
Senior Designer
Enkei America, Inc.
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
If you're talking about Instance Geometry then you can add or remove geometry from the selection criteria quite easily.
For feature instances of rectangular or circular arrays there does not appear to be scope for ordinarily changing the selected content. However you can get around this if you plan for it by adding the features that you want to include in your array to a group, or feature set as it will be listed in the feature navigator. Then you can select the feature set as the item to array and later add or remove feature as required.
Cheers
Hudson
