NX11 - Template File path
Kenja824
Automotive
I am just helping someone figure this out and it is not my area of expertise.
Right now we have the template files in the C:Drive and if we need to add a new template file for a new customers standards, we need to add it to every person's computer.
Is it possible to direct NX to a shared drive to keep the template files so we only need to place it in one folder and everyone's computer will pull the templates from that folder? Where do you change the path?
Most definitely. You can put the files on a shared drive and then run the configuration program to customize where the files are installed. This will also need to be done on each workstation, unless you use a server-hosted installation of NX.
Putting everything on a server eases upgrades and configuration.
Ben Loosli
Thank you. This is a little too in depth for me but I will definitely pass this on. I do appreciate the help.
