Hi Guys,
stupid question but I have a simple operation to perform in the milling machine and was wondering what the standard way to do it was. I have a steel disc and and want to remove 1mm off the top surface (facing op to clean it up from the saw) so it is ready for the next op on a different machine. How do I do this? I wanted to set the blank and add 1mm to the height then simply run a floor wall op to remove the unwanted material. When I touch off in the machine I am always cutting my 1mm of material thickness in air. I can of course cheat and fiddle with my Z offset but this seems a bit silly, likewise the mcs...
Can someone enlighten me?
many thanks,
James
many thanks,
James
