Thank you, thank you! I thought you might be interested in what happened when the whole group tried to reach an agreement on the standards. It got a little heated. We still have not implemented them, because there's no one to enforce them.
* means mandatory:
Applies to all new models & files. Standards to be met prior to checking & drawing release
0. One primitive maximum. First feature located at 0, 0, 0.
No centered blocks—a corner must be at 0,0,0.
*1. No suppressed features
Exception: detailed threads may be suppressed
*2. No Out-of-date features
*3. No blanked objects
*4. Sketches fully constrained – except, for example, extruded text curves
*5. No “Fix” sketch constraints
*6. Proper layers
1 sketch per layer, generally
Categories must be assigned to every layer with an object on it
Category names for sketches must match sketch name
Master layers: Solids 4-100, all else 101 and up; 256 file notes
Drawing layers: Pattern 1; drafting annotation 3; components 4 & up; File notes 256
* 6a. All sketch names start with SK and have a descriptive name. Default name not allowed.
*7. Reference Sets set (solid, mating, drawing are minimum required ref. sets, each contains solids except for files with no geometry)
*8. Attributes assigned (must match between drawing & master)
*9. Item & file named properly
*10. Mating conditions must have a minimum of 2 constraints per condition.
Exceptions: models with no geometry
mate taper to taper constraint
Base component
*11. No dumb dimensions except “Text”
*12. All symbols & notes associated to views, “relative to view” is minimum origin type. Exception: Main block of notes
rev. blocks by main notes (preferred that rev. blocks are part of the notes)
13. No unparameterized features (applies to new models)
Exception: Vendor-supplied models
Models converted from SolidEdge
14. Scale expression preferably linked to drawing views & matching title block scale, unless scale is NONE
15. No faked parts lists (preferred)
*16. No suppressed components (assemblies)
Exception: Members of part family assemblies
17. Smart ID balloons when smart parts list is used
18. Smart callouts in drawing notes when smart parts list is used
19. For a part family that is saved to a new part number: family spreadsheet deleted, or all instances updated to new part number
*20. Correct assembly structure
*22. Component name matches item ID
*23. Non UG datasets that are linked to previous revisions must be cut from new revision
24. Photo materials assigned in master (optional)
25. Solid density assigned in master models
Exceptions: parts that will not be sold, like production fixtures
Assemblies
BEDocument types
Parts with no solids
26. Use expanded view for faking stuff--no lines/text that appear over a drawing view allowed on drawing sheet
28. NO interpart expressions
Exception: drafting expressions
30. Use feature ISET for arrays (recommended)
31. Assemble in order—create in order : For example, if you assemble washers to bolt holes, first assemble the washer at the beginning of the series, then the next closest, and so on. Don't assemble the 1st one, then the fourth, then the second. Do the same when making the holes: make the 1st, then 2nd.. (recommended)
32. Don't embed a feature in a feature: Don't make a cut to remove unwanted features. (recommended)
33. Links broken
*34. Family members updated
35. Title length per company standrd (total of “title” plus “title2” part attributes). Preferred that all characters be assigned in “title” attribute.
36. Do not revise a part family member. Saveas on a part family template to a new part number is not preferred.
*37. No unassociated OBJECTS (Dimensions or Leaders)
*38. File must be saved as follows:
Drawing File, Sheet 1 in drafting.
Master model, modeling, shaded, only solids visible except for file notes, fit to screen, unexploded, layer 256 (File Notes) visible, model oriented to show best view & detail
*39. No extra dwg sheets
Drawing only. Delete all unused sheets from drawing file.
40. File notes
Layer 256. Layer Category to include view name that notes are placed or be View- Dependent-Edited, View-to-model to allow it to show in all views.
The note should contain any non-typical model or drawing features or practices that had
to be used in the file or any information that would be considered helpful to the next
person to work on the file. The notes, when needed, should be simple and concise.
*41. No incomplete models allowed (missing features), unless a file note is created saying “This model is incomplete” and the note must be included in the solid, mating & drawing reference sets.
42. No MAX dimensions. Models and features shall be nominal
*43. Attributes in Title Block (not dumb text)
44. Correct Item Type in TeamCenter Eng.
