TechnicalConsultant
- Mar 26, 2004
- 172
Morning all,
I'm hoping someone can help me on this one. When producing sheet metal parts I dont want the flanges with a minimum bend radius to give me any additional material on the flat pattern. I can change the formula to give me this but if the part has a bend with a radius which is actually important and dimensioned on the drawing I would want the bend allowance formula to work.
In older versions of NX I used a formula which basically said if the expression of inside rad exists and is to the value of 0.01 then give me 0.01 material. If not use the traditional formula. This doesn't seem to work in new versions though.
Any thoughts appreciated.
