NX, Properties
Vishu_18
IN
After running my custom application for 2 to 3 times (sometimes even for 1 time) when I try to open the properties of any component or any PMI properties a UI Pops up by showing internal error.
Can someone help me with this, why it's happening and how can I prent this.
I think this description is to vague to try understand anything about.
You need to add more information on what your custom application does , and the errors NX returns.
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.:-)
As Toost says, this is very difficult to diagnose based on the short description given. However, if your code uses a builder object, check to see that you are destroying the builder after using it. I've forgotten this step a few times and it lead to some strange behavior in NX.
www.nxjournaling.com
Majorly we do creating PMI's through builders and creating points, attributes in routing application.
