NX Open , .Net , Point3d
Vishu_18
IN
My input is a point3d. I have a array of point3d and I want the nearest point among those points. Do I have any API or any other direct method of getting it, instead of checking distance with each point.
Just cycle through and measure the distance to each point. You can compare squared distances, instead of actual distances, which will avoid a square root calculation. I’d expect that you can cycle through millions of points per second; performance is not likely to be a big problem.
