Does NX have the ability to section, and eliminate half of an assembly, so that the remianing solids can be turned into an STL file for printing?
I have a large fabrication assembly made up of several hundred parts. We'd like to make a 3D Print of half of it (so you can see the internals). It is a frame made up of welded plates. Some plates cross the plane we will use to cut it in half, but most parts reside entirely on one side of the section plane or the other.
Right now, it looks like I have to parasolid them, unite them all into a single body, and subtract a block from one side? This is super labor-intensive, and many parts are just touching and may not unite very well.
Thoughts?
