NX Attribute Driving another Attribute
Goddard1967
Hello fellow NXers,
I am trying to do this. I have an attribute called NX_MATERIAL. I want the default Material attribute to drive its answer into the answer for NX_MATERIAL. In other CAD packages I can just say this attribute is equal to that one. NX doesn't seem to work in this fashion. What am I missing on trying to accomplish this?
Thank you for your help.
New to NX,
Randy
Here is one method (it is a bit easier in NX 9 and above). The steps below assume you are starting fresh with no attributes created yet.
[ol 1]
[li]switch to the modeling application[/li]
[li]create the NX_MATERIAL string attribute (leave the value blank for now)[/li]
[li]assign a material to your solid body (Tools -> materials -> assign material...)[/li]
[li]start the expression editor (Tools -> expression...), change the "listed expressions" filter to "attribute expressions"[/li]
[li]if the material attribute does not show up here (it probably won't), press the "reference part attribute" button, choose the "Material" attribute (the NX generated one, not your blank attribute); you should now see an attribute expression such as "p1 (Part Attribute:Material)", cancel the expression editor[/li]
[li]go to the file attributes, select your attribute (NX_MATERIAL) and choose "link to expression"[/li]
[li]choose the expression that showed up previously and ok the dialogs[/li]
[/ol]
www.nxjournaling.com
You guys are the best. Thank you very much. I knew it could be done.
Thanks again,
Randy
